Wayne_Dohnal
May 02, 2013Explorer
At a typical 80% efficiency and 0.7 power factor, a maxed-out 60 amp converter will draw over 1,500 VA, and a maxed-out 75 amp converter over 1,900 VA. You can get away with higher than 60 amps on an eu2000i if you're willing to make sure the battery doesn't get highly discharged, cut other loads when necessary, and/or manually kick the converter out of boost mode when necessary. If you really need the bigger converter, a power factor corrected model might be justified.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
