renoman69
May 02, 2013Explorer
Wayne Dohnal wrote:
At a typical 80% efficiency and 0.7 power factor, a maxed-out 60 amp converter will draw over 1,500 VA, and a maxed-out 75 amp converter over 1,900 VA. You can get away with higher than 60 amps on an eu2000i if you're willing to make sure the battery doesn't get highly discharged, cut other loads when necessary, and/or manually kick the converter out of boost mode when necessary. If you really need the bigger converter, a power factor corrected model might be justified.
whatever....I have watched my Iota 75 put 73 amps into the 50% battery bank while being powered by my Honda eu2000i.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
