Gdetrailer
Jan 28, 2021Explorer III
mcewena wrote:Gdetrailer wrote:mcewena wrote:
I've got to take part of the blame for this one. I was assured by several people that the dometic 300 was a plug and play replacement for my unit but the supply line faces the rear as opposed to the side like the old one and even with the shallowest elbow I could find it still tweaks the valve assembly on a rear bulkhead when in use. I thought I shaved enough off the bulkhead but apparently not. More exacto knife required.
Change the stiff PEX supply line to flexible plastic line with braided stainless steel..
Thanks but no. The problem is the dometic supply points directly at the bulkhead wall and there isn't room to put a standard elbow on it nor the ss line without it rubbing against the wall and constant pressure being applied to the valve assembly which, over time, causes it to leak. I solved it by attaching an elbow directly to the supply line and screwing that elbow into the valve assembly BEFORE snapping the assembly into to the toilet.
Sounds like you need a "short radius" elbow or something like a "street Ell" to connect the valve to the supply line..
If you had a PEX crimper, you could change the fitting on the PEX with a 90 degree swivel which has a very tight and short radius..
Another option is a "TEE", cap off one side and connect line to the other..looks like this..
Now days, you do have to use your imagination and rummage through nearly every store you can find in order to get every fitting you need.. Sure miss the little hardware stores on the corner that had every single obscure plumbing item..
I still stand by the suggestion of using the flexible braided line, no matter how much you play with bending PEX, it will want to go back the way it was .. Flexible lines remove all of the pressure that PEX would create on the water valve..
But you may get better ideas if you were to post a photo and a couple of the dimensions for clarity.. We are only able to guess as to the issue you have and the space you have to work with without a photo..
I have changed not only the toilet feed to flex lines but the bathroom sink and kitchen sink also..
On edit..
Found a 1/2" to 1/2" street elbow..
Found HERE
Which has a very sharp 90 degree turn that would allow some space over normal 90 elbows..
You can use the measurement in the photo above to get an idea on how tight it is..
Was looking to see if there was any flexible braided hoses with 90 degree turn on them but looks like not much other than hose bib ones for washing machines..
Like these..
Sure would be the cats meow if you could find that in 1/2" pipe thread..
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
