mcewena
Jan 29, 2021Explorer
Gdetrailer wrote:
Now days, you do have to use your imagination and rummage through nearly every store you can find in order to get every fitting you need.. Sure miss the little hardware stores on the corner that had every single obscure plumbing item..
That's for sure.
I forget the fitting I eventually found (this thread is 6+ months old). It was a gray elbow and had internal thread that fit onto the valve thread and with a heat gun I managed to get the OEM Winnebago tubing around the lightly barbed fitting.
It was still a no-go until I had my euraka moment of fitting it to the valve assembly before attaching that to the toilet.
I tied the brass elbow you pictured but it was too small for the OEM Winnebago hose/pipe/tubing.
Sharkebite and SS pipe was going to be my last resort as I would have had to pull out some of the bulkhead and it would have looked like sh*t.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
