cloeknox
Mar 14, 2022Explorer
LED lights should not be selected by power - efficiency in different lamps is different. The lamps with the same power can vary greatly in brightness: lamps that replace the usual light bulb-pears 60 W can have a capacity of 6 to 10 watts, lamps that replace the ""candle"" 40 W can have a capacity of 4 to 7 watts.
Most manufacturers of LED bulbs indicate the equivalent wattage of incandescent bulbs. For example, the packaging may state that the vont.com bulb has 6 watts and shines like a 60-watt incandescent bulb. Some manufacturers indicate this equivalent quite incorrectly, so I recommend that you always pay attention not to the equivalent wattage but to the luminous flux.
