Gonzo42
Feb 07, 2014Explorer
I started looking for LED replacements for spares and reliablility but I soon found that in my case the turn signals have to be the incandescent variety or the turn signal timer won't work properly. The timer module is not replaceable without changing the entire switch assembly. Howeve I did find LL (long life) versions at Autozone and Walmart so I have those as spares.
Note: if you clean the contacts on your bulbs and the contacts in the sockets use ONLY a white pencil eraser. If you use a pink eraser, the red phosphorus in it will promote corrosion.
