BFL13
Jun 15, 2014Explorer II
Don't replace the 6300 with a 7300 using that kit nor replace it with the Ultra kit or you end up with the dreaded WFCO.
That leaves the PowerMax or PD as a replacement, either of which will work well.
If the distance from the existing converter to the battery bank is long (over 10 feet) you should see if you can fit a deck mount converter close to the batteries instead of installing a new "lower portion" converter.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 21, 2026
