jeeperdude10's avatar
jeeperdude10
Replacing 40 inch living room TV
I am in need of replacing the existing, original LG 40 inch TV in my 2016 Bounder 35K. My question is can I mount a 43 inch with my existing hardware that TV is mounted to, or does other make 40's have the same mounting positions built in as the LG? Before I remove and manipulate and 'mutilate' existing, would like some idea of what I may be looking at. Thanks in advance for any and all thoughts.
  • philh's avatar
    philh
    Explorer III
    does your mount has multiple holes or just one? Measure them and compare to the TV you want to put up. The dimensions will be listed in the TV detailed specs. Be aware, the dimensions are metric.
  • All the Flat Screen TV that I have seen come with standard mountings in IIRC 2 spacing patterns. Not sure at size they change, but you should be able to measure the pattern on the back and compare to the new TV.
