obiwancanoli's avatar
obiwancanoli
Replacing 50A Electric Cord
Has anyone replaced the electric cord on their MH, the one you hook up to shore power? Is the cord specific to the MH, or will a generic cord work too? Can it be done easily, or is it something you'd have a service tech do?
  • I replaced the 30 amp cord. No big deal, just follow the end of the cord as it goes into the RV and find where it is spliced into the RV electrical. Remove the old cord and splice in a new one. The cords are generic. I had to remove a tail light to get enough room to work in. Just make sure to match the colors.
  • Is your cord detachable at the rig?
    Fairly easy job in most cases. Some times you can get a 35 foot extension cord, remove the coach end for less dollars then buying parts.
    It is hard to find good cable that is flexible. Most cable is 6/4 cable. Many RVs use 6/3 plus # 8 ground to reduce size and weight.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
