Chris_Bryant
Jun 15, 2014Explorer II
smkettner wrote:John S wrote:
The molded 30 amp plug on my umbilical cord is pulling away from the cord. Tried pushing it back but to no avail.
Try again. On a hot day lay the cord out full length in the sun for an hour. Then start by the RV and work your way toward the plug using a sliding grip to work the outer casing out to the plug. Use some adhesive at the plug to hold it in place. I used JB Weld.
This ^^^^^. As long as the plug itself is in good condition (I use goop to glue the casing to the plug).
If replacement is required, I highly recommend the Progressive Industries one- it has real lugs for the wire, rather than a simple screw terminal like most of the others, and a round ground pin, rather than U shaped.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
