time2roll
Oct 28, 2014Nomad
jrnymn7 wrote:I don't think the question was even close to the same. IIRC BFL's primary concern was to increase the charging amps with 4 to 5 batteries. I suggested a second portable charger would work fine. Eventually there became FOUR such chargers and I have been since suggesting a slower charge might be OK also as it relates to reported drops in hydrometer testing. Been bantering a few years now. I don't thing we take each other too seriously ;)
Yes, I agree, smk is not necessarily 'one of those', but what IS his point? You offered a suggestion to the OP... the exact same suggestion smk offered you.
If the OP decides the 45 is too slow we can go from there.
jrnymn7 wrote:Great set up and very similar to the OP. Are you inclined to go 80 amps?
I have seen this shift in when amps begin to taper when using a lower charge rate as well; like 45a on a 215 bank. I have seen my 45 take my bank well past 80% at full current.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
