NinerBikes
Oct 30, 2014Explorer
mena661 wrote:jrnymn7 wrote:My experiences with my own batteries. C/7 charging doesn't get my SG any higher than BFL with his fast charging. I've even charged at C/5. The best I've seen was 1.265 (C/7) with it mostly hitting 1.260 or a bit lower. I've been using BFL's charging methods since I got my batteries. I've tried the converter only method with 3 different models. My batts are pampered big time. Doesn't work for me. YMMV.
If it is true, 'speed charging' leads to lower sg readings, I would definitely like to see the evidence.
A week of camping with the PD 9245 in winter, and the Trojan Scrubber battery, running solo, pulling 40 amps amps a day, had me at one cell at 1.250, and the rest at 1.260. My idiot gauge always said I was 2/3 charged, as soon as the generator was turned off. Voltage was about 12.62 to 12.68 with the surface charge removed. With the Mega Watt, 12.73 is pretty common. SG is up 10 to 15 points also when using the MegaWatt at 15.0V. Since I see only 50% discharge cycles allowed, going from 50 to 90 to 50 to 97% adds about 14%, or the battery ends up at 57-97%, is my guess, hypothetically.
As landyacht318 found out 15.3 doesn't seem to hurt a thing on his Group 31. I don't think the T-1275 is much different. GC-2's are just much more efficient at charging back up quickly, with less effort, baby sitting or hand holding. Some shapes and designs need a little bit of brute voltage to get them topped off while charging, others, GC-2's, maybe L-16's too, seem fine with running the 14.4V the PD 9245 or 9260 puts out, or if you have big battery banks, the 9280 or 92100 models.
Run what makes you happy, for a charge controller, if it doesn't make you happy, change it, or get a pendant, charge wizard or the IQ-4 for the Iota series. Or spring for the new Boondocker adjustable voltage model that Randy makes over there at Best Convertor.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
