smkettner wrote:
80 amps for what two minutes? Then you are tapering quickly and will have BFLs sulfation issues requiring extended top charging upon return.
A pair of Trojan T-105's in series have a capacity of 225Ah's. At 50% dod, that is (-) 112.5Ah's. (let's say -112).
At 80 amps charge current, it would take a little more than two minutes to do a 50-80% bulk charge... more like 50 minutes... during which time ~ 67Ah's would be replaced... regardless of how many current limiting chargers are used to produce that 80 amps of charge current.
(But yes, a 79.988149% - 80% charge would only take 2 minutes).
Then, amps would begin to taper slowly from that 80a charge current. Shortly thereafter, the charge current would indeed drop off rather quickly, as the battery builds resistance. This will result in the next 10% charge (80-90%) taking about 30 minutes to replace only 22Ah's. The final 10% would take upwards of 2-3 hours, depending on the particular battery's inherent resistance.
This is all normal when charging flooded lead acid batteries. Moreover, sulfation is reversed during charging, not created, so how bulk charging a pair of 6 volt gc-2's at 80 amps will increase sulfation is a complete and utter mystery to me???
Perhaps smkettner is referring to BFL doing 50-80% cycles; which will indeed result in sulfation build-up, and even stratification... IF AND ONLY IF left unattended to for prolonged periods. But other than this, charging at a higher charge rate, which btw, requires higher Boost/Vabs settings, simply cannot, and will not, lead to increased sulfation. In fact, the higher voltages and resulting higher currents will decrease sulfation better than charging at barely more than a float charge (i.e; at 13.6v) from 80-100% for days on end. And the simple fact that the batteries are accepting the charge rate, AND quickly building resistance proves that desulfation is indeed occurring.
