Seon
Sep 29, 2020Explorer II
Trailmanor13 wrote:
I was thinking of using my sawzall with a diablo metal blade and cutting 8 cuts about 1/4 of a inch in and using a vicegrip to bend them out some and then tapping the jack into the hole. The top hole in the A frame is big enough, just the bottom hole is too small. The metal is less than 1/8"
Spot on.
or use an angle grinder like this for less than $40:
https://www.homedepot.com/p/Stark-8-2-Amp-Corded-Electric-4-1-2-in-Angle-Grinder-with-11000-RPM-Sliding-Lock-On-Switch-45501-H/311884247
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
