mikestock
Aug 05, 2021Explorer
wa8yxm wrote:
YOu might need some lubrication on moving parts.
You're right. When I hear some of the sounds it makes I'm sure of it. I sprayed all the parts I could access with WD40 but it didn't help much. I haven't had enough time but I will have to look further. I have the MH stored and when I work on it I have to have someone close by my wife or take her along, which she doesn't like.
The pdf that Doug sent gave me a lot of things to check. I have an extra wheelchair battery that I can parallel the input voltage when I get another failure. I haven't checked the voltage at the control box as the awning is operating. This is highly suspect since the awning still stops with the new controller in place. This, along with proper lubrication might just be the answer to my problem.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
