pirlbeck
Nov 20, 2017Explorer
Replacing a Jensen "flying saucer' antenna on a Lance
Last summer we lost the Jensen Omni Directional ANHD20 while traveling across Wyoming in very high winds. Not much of a loss, as it did not work very well anyway. I am looking to replace it with something better, but I would like to reuse the existing mounting location. I am pretty sure using the existing location is pretty much going to rule out any sort of "crank up and rotate" antenna due to the area where it is mounted, which is above a non-opening area where the radio and other electronics are located. I though I may of read somewhere about a remote controlled antenna and that maybe an option.
This is on an 2009 Lance 845.
Anyone been down this road and what did you replace it with and how did it install?
Thanks!
Thanks!
