69_Avion
Jan 01, 2014Explorer
rfuerst911sc wrote:
I do not recall any additional regulators on any of the appliances. To be honest the only " old " appliances I will be using is the oven/range and water heater and I don't think the water heater is original. I will be going to a vented cat heater and I have a newer Dometic fridge to install. The idea of having a tank mounted regulator for the extra tank I had not thought of thanks for that suggestion.
69 Avion you have so many hoses/fittings in that second pic I got dizzy ! I assume the quick connects are for when you tap in aux. LP items ?
You are correct. The Rego regulator will handle anything that I use with it including a 30,000 btu stove and an outside water heater.
