silverbullet555's avatar
Oct 05, 2020
Replacing gas regulator and hoses
Well, the camper has been living in the back of my truck for a bit. My oldest and I have been taking it out for hunting season. Camper has worked well, hunting not so much.
I want to improve the connection for the gas tank. The way it is now, the regulator screws into the valve for the gas tank and then a flexible hose goes from the regulator to the connection to the gas system. I have to hook and unhook the tank to go anywhere and the door won't shut when the tank is hooked up.
What do I need to know about regulators and hoses to get this set up correctly?
Single stage vs dual stage regulator.
Horizontal vs verticle regulator.
Potential issues with fittings on a 1995 camper. I would prefer to switch over to the tank fitting which I can just screw on by hand unless there is a reason not to.
The propane is used in the water heater, stove/oven, fridge and furnace.
