Chris_Bryant
Apr 19, 2015Explorer II
I would go with the Briskair II- pretty nice unit. While it should be plug and play with the old inside assembly, you can install the new Dometic digital t-stat- the only disadvantage to going with a new inside assembly is that you are stuck with the Dometic t-stat- with the original assembly, you can use a standard one (i.e., hunter, et. al.)
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
