STBRetired
Aug 06, 2017Explorer
To replace the compressor, you will need the following:
Brazing torch and silver solder
Replacement compressor
Solder-on charging ports
Filter/drier to add to system
Vacuum pump and manometer
Manifold gauge set with hoses
Freon refrigerant of the proper type
Suitable scale to measure charge
Unless you have access to all of that, I would try the Easy Start kit and if that does not solve the problem, look at a new unit online. Hardest part of replacing an A/C unit it getting the new one up onto the roof.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
