dougrainer
Apr 29, 2016Nomad
rockhillmanor wrote:dougrainer wrote:
.... As to an "arrow" pointing which way?????? In 37 years whether it was Valterra or Bristol, I have NEVER seen an arrow and if you REALLY understand the design and how the flanges/seals are utilized, you would know that the valves have no front or back. .... Doug
I respectively disagree with you and really take offense that you choose to post a bash and call me a liar.:R
There WAS an arrow on the flat end on the top indicating the direction of the flow of water. The arrow was a molded part of the blade not a label so it was the same color as the blade.
AND if YOU REALLY understood the valve blade. The Bristol valve I installed DID have a front and back. A look at the blade itself showed that they were NOT flat but that one edge of the blade itself is slanted to fit. Arrow on top showed that the slant on blade should face the water flow.
Is this arrow still on the newer Bristol valves I don't know haven't had to replace one in the past few years. But do NOT call me a liar and that I don't understand. If you want to bash forum members find another forum to do so.
I did NOT call you a Liar. YOU took what I posted to think that. I guess the excess of 500 of Bristol/Valterra valves I have replaced over the years, even tho according to you I had a 50/50 chance of getting the arrow pointing the right way, I somehow ALWAYS installed it correctly. ALL the valves I have seen are slanted on both sides. Can you take a pic of yours showing this arrow? Doug
PS. I opened up some 3 and 1.5 inch valves off the parts shelf and NONE have any arrows. Doug
