rrev wrote:
Any tricks to wiring up the Honeywell thermostat or is it the same as the Coleman one I'm replacing? And just for my knowledge, why wouldn't the Dometic one work?
Dometic uses a digital signal to a relay box specific to Dometic.  Just 3 wires to the thermostat and 2 are for 12v power.
It might be possible to adapt the relay box.  You would need the wire diagram for both and connect accordingly.
Possibly Coleman has a digital replacement that is compatible?  I would look there first.
Here is my Dometic install for comparison: (I have a Dometic A/C)
 > Dometic digital thermosta
