Bill_Satellite
Aug 13, 2018Explorer II
I replaced mine with a Winegard automatic but they are no longer available. The biggest problem with removing the Concord (Brawn) is that the motor is under the mount and it leave a huge hole in the roof when removed. I was quite surprised that anyone designed this thing that way. I would guess that this is about a 5" hole. The wiring is also not compatible (other than reusing the coax if you choose) so you either need to plan a new wiring run or install something like the Winegard Razar Automatic (dome) which only requires a coax run.
The other option is to simply seal up that big hole and install the Winegard Sensar IV crank up style antenna for the very best reception option. You will just have to look over the roof area to see if there is an area with space available and there is space below that location inside the coach where you can drill a new hole and install the crank handle on the ceiling.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
