time2roll
Aug 16, 2020Nomad
If your current controller has a fixed charging profile you could benefit with a full function adjustable MPPT controller. Also you can overdrive your MPPT controller a bit with more panels and the controller will just limit the output to the controller rating.
In parallel you will want to match the voltage specs (Vmp) of the panels as close as possible. In series you want to match the amp rating.
The Morningstar MPPT is excellent and very programmable although it is a bit of a premium price.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
