3_tons
Sep 02, 2020Explorer III
BFL13 wrote:3 tons wrote:``````````````````````
“Controllers don't compete.”
A single stage controller mixed with a multi-stage controller can cause the multi-stage controller to prematurely switch to float mode, effectively cutting out that controllers harvest - Sometimes referred to as “dueling controllers”...For clarity, not a theoretical matter, this how it can happen...
3 tons
Nope!
Say the multi-stage will drop to 13.6 two hours after reaching 14.6 (typical EP Solar fixed profile). Now start off with your single stage set at 14.6 in parallel.
"Prematurely" is only because it gets to 14.6 sooner with both on the job. It is not premature wrt to battery SOC.
Two hours after the batts reach 14.6, the multi will drop to 13.6 but the single stays at 14.6.
Whether this is good or bad "depends"
Got it, I’ll take that as “it’s a settled science”!
3 tons
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
