3_tons
Sep 03, 2020Explorer III
pianotuna wrote:
Trust BFL13 to have "the goods"! So it is not just multiple battery chargers * grin *
Well, I must say that I’m a bit confused - blame it on a previous thread??:
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29173556
Per BF13:
“They will add their amps ok at first in the morning but then it gets complicated. The ViewStar has that fixed EPSolar charging profile where it gets the battery to Absorb voltage (for AGM as set by you) then holds that for two hours then drops to 13.x (AGM setting) Float.
The Bogart controller is different ISTR you can set voltages? So set that one as close to the ViewStar charging profile as possible for the longest period in the day where they both have the same charging voltage.
Any time one has a higher charging voltage than the other, the lower voltage one will not put out any amps at all to the battery and you are on just the one.
EDIT-When I did that a few years ago, I was using two LandStars on the one battery set, so the two controllers were identical. Worked great. Maybe get a second ViewStar instead of the Bogart?
* This post was edited 01/31/17 10:43am by BFL13 * “.....
This IS closely similar to what had happened to me (until I found a workaround...), and note that this is why I cared to mention it to the WIDER Audience...A few imprudent keyboard clicks won’t erase what was this ‘real-world’ (non-theoretical) experience.
3 tons
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
