BFL13
Sep 03, 2020Explorer II
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29173556
Not sure what the argument is about. In the above, I did say something not quite right, but not sure that is what is the issue here.
In fact, the lower voltage charger does keep adding amps, but they taper as the battery's voltage gets closer to the lower charger's voltage. Once the battery voltage is the same as the lower charger's voltage it does no more amps and the remaining chargers with higher voltages than the battery is at (and rising) keep adding amps.
Some smart chargers won't start if you start them in the wrong order, but that is a different topic? You start the lower voltage smart charger first and it gets going , then you start the higher voltage charger. Now they both run and add their amps.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
