Gdetrailer
Dec 18, 2015Explorer III
TenOC wrote:
My 2005 Carriage Travel Trailer (yes carriage made a few TT) front window (bottom half) is broken thanks to my DGS (Dear Grand Son) and a BB gun.
Has anyone replaced the glass in a TT window? Big Deal?? Since Carriage is out of business, I think I will need to use Plexiglas or PolyCarbon that I can trim to size. Any on line video on how to? . . . :h
While Plexy or polycarb could be used, they are not really all that great.. Plexy gets extremely brittle in very cold weather and scratches extremely easily AND is very expensive. Polycarb has strength but also scratches extremely easily along with an even higher premium price tag.
Glass is over all the best way but not just regular glass, it MUST BE TEMPERED GLASS. This is not something anyone can do and once tempered cutting it is nearly impossible to do without shattering it.
You BEST bet is to check with some HOME AND BUSINESS GLASS SHOPS, these are the places that service mainly businesses for store front and general building windows.
They WILL most likely need your window frame, they will color match your glass then cut to size. Once cut to size they will most likely have to send the glass out to a third party which has the proper equipment and systems to temper the glass.
The cost of tempering is not all that expensive and is well worth having done.
Tempering glass changes the glass structure adding strength and increasing YOUR PERSONAL SAFETY in the event of breakage.. Tempering prevents the glass from breaking into very large sharp shards instead it will shatter into millions of less sharp pieces which are far less dangerous.
Now days it IS called "safety glass" but in reality it is non laminated tempered glass which IS required for pretty much every US state in motor vehicles AND RV trailers on public roads.
You can confirm what I have written by checking the corners of your other windows in your trailer, you should find a small logo in one of the corners which will state something like TEMPERED or SAFETY glazing..
Only vehicle windshields are required to be LAMINATED TEMPERED glass so lamination in your case is LAMINATION NOT REQUIRED BUT TEMPERING IS.
In the past many people on this forum have been rather confused about this so that is the reason for this long explanation..
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
