Tara338's avatar
Tara338
Replacing interior lights
Are there any issues replacing an RG921 incandescent bulb with a 921 LED from an automotive store ? Or does it have to be a specific LED lights for RV’s
  • The only issue I had when I replaced all our RV bulbs with LED bulbs is that the LED bulbs flicker due to voltage fluctuations when the water pump is running. With incandescent bulbs they would dim a bit when the pump kicked in, but the LED bulbs flicker.
  • It may be best to get an led bulb that can tolerate higher voltages.
  • Bulbs are bulbs. No such thing as an RV bulb or LED. Now some LED’s will interfere with things like OTA tv signals.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 20, 2026
