dougrainer
Mar 12, 2020Nomad
Pulling the furnace will not get you to the limit switch. You remove the Blower wheel cover and blower wheel. Once that is done you can get to the Limit switch. I use a 14 inch 1/4 inch drive socket extension with a phillips bit on the end and use very long needle nose pliers to remove the 2 white switch wires. Remove both screws on switch and remove then install new and connect wires. Have a LONG magnetic pick up tool to get the screws if you drop them. Make sure the 2 white wires are NOT too close to the burner chamber when you are done. Doug
PS, The flat rate is .9 hour to do this
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 22, 2026
