1ofmany
Jun 12, 2016Explorer
mobilefleet wrote:For the benefit of dpgllg, if you leave the existing vinyl flooring in place and cover it with new flooring, like some of the flexible products mentioned, you WILL see a hump where the old vinyl leaves off and the subfloor begins (like where you removed carpeting). Just to be sure of my information, I just leaned forward and looked at the part of my FW floor where I did the same as dpgllg is suggesting: yep. A hump.1ofmany wrote:dpgllg wrote:You may want to rethink leaving the existing flooring in place...if you do, you may end up with a visible "hump" where the new flooring covers the old.
If I want to replace both the vinal and carpet how do I handle the slide out? The carpet is split down the middle at the slide and slides across the fixed carpet.
I will keep the existing vinal and lay the new over it.
Thanks
Dave
nope. Not an issue
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
