MadFinnHockey
May 02, 2017Explorer
Linoleum replacement
its about time to replace the linoleum in my 2003 Coyote, its separating from the floor and its time to go, and I have a few questions for those who have replaced theirs. I'm thinking of replacing it with square linoleum/vinyl tiles, or a floating floor. So here are my questions:
If you have used the square linoleum/vinyl tiles, did they stick well to the old existing sub floor? Did you pre-treat the sub floor with anything (paint, sealant, etc) to make them stick better or to prevent moisture?
If you replaced your flooring with a floating floor, did you pre-treat the sub floor with anything, or lay down a vapor barrier/shield?
Thanks!
Thanks!
