MadFinnHockey wrote:
So its hard to tell from the pictures RJXJ, but how did you installed the tiles when you got to the cabinets and other furnishings? Just you just get as close to the cabinet as possible, did you remove some furnishings to put the tile under them, use trim to cover the edges?
Thanks and it looks great!
Thank you. In the areas where I cut the carpet there was room to slip the tile under the edge of the paneling. When they build the rig they put walls and other items right on top of the carpet so when you cut it out there is sometimes enough height to slip the tile under slightly. I just cut the tile closely along the cabinets and bath tub etc. I then used a color coordinated caulk for the edges. I did use a quarter round on one living room wall under the television area. The tile was very easy to work with and if I messed up on a cut it was only a dollar something or I used the bad tile somewhere else.
If I did it again I'd do it with a grout line. I dont see how a regular cement based grout product such as we would use in a house would work in a flexing floor like this. I had considered
THIS product for the grout lines because it's silicone based and did use it around the edges. I was a little nervous because you dont hear a positive word from anyone in the stores and sometimes on here too. Some in the stores dont even want to talk about it if you say RV. I pictured it being easier to deal with loose tiles if I didn't install grout lines but that never happened.
I'll try to get a few more pics later.
