pianotuna
Mar 13, 2021Nomad III
Many of us have two inverters. One for loads up to 300 watts. And then another for the heavy loads.
I have a female plug that is powered from the inverter. I simply plug in the male 30 amp shore power cord.
I leave my converter unplugged.
I added a plug for the water heater.
I manually set the fridge to propane.
In your shoes, I would go with the 375 watt Victron.
https://www.amazon.ca/Victron-Energy-Phoenix-Inverter-VE-Direct/dp/B01N0W4H34/ref=asc_df_B01N0W4H34/?tag=googleshopc0c-20&linkCode=df0&hvadid=335446326166&hvpos=&hvnetw=g&hvrand=5455692531185080015&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9001253&hvtargid=pla-594162739802&psc=1
When you expand the battery bank, consider if you need a larger inverter.
