fallsrider
Nov 05, 2015Explorer
MagneTek 3240 replacement
My converter in my '95 Sunnybrook TT has started intermittent humming and the lights are dimming. Based on what I've read, this means the converter is probably going bad. Correct?
I have a MagneTek 3240 unit. I have never replaced one or worked on one, other than checking fuses. This unit sits in a plywood stand under the sofa. Removing the sofa will make it very accessible.
What replacement unit should I consider? It is a 40 amp unit. I would think I would want a smart charger in the new unit.
Thanks.
Thanks.
