time2roll
May 12, 2017Nomad
PM4 is well known to drop to trickle charge at about 3/4 full. Probably even less with 100 amps into just two batteries. Fine if plugged in but not so good on generator unless it runs all day. Possibly you purchased a manually controlled PM4?
Since 100 amps is probably too much for the existing circuit you may as well mount it close to the battery with #4 or better 12v wire.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
