Steve92004
May 12, 2017Explorer
BFL13 wrote:Steve92004 wrote:
So should I pick up a smaller converter/charger?
If you can return the 100 and get a 60 instead that would make more sense IMO. (Get the new PM3- LK model too, not the older PM3 or PM4 type--the LK has an adjustable voltage, which is great for matching to your battery charging specs)
Another thing is what generator do you run the converter with off-grid? You could run your old 30 amper with a small gen, but a 55 or 60 amper will need a 2000w (1600 continuous)--a 1000 is not enough. I need my Honda 3000 to run my PowerMax 100 doing 100/14.8
The generator is a built in Onan 4000 Microquiet
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
