BFL13
May 12, 2017Explorer II
Yes. The original battery to converter wires (which also did converter to battery) are sufficient gauge to run the rig's 12v from the battery when not on shore power/converter, so they stay as is.
The new converter can run the rig's 12v by being on the battery which is connected to the fuse panel, so all is good.
Use #4 short wire (under three feet each wire) from the 60 amp converter to the battery to be sure of getting your 60 amps. (if that is the size converter you get)
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
