Steve92004
May 12, 2017Explorer
BFL13 wrote:
Yes. The original battery to converter wires (which also did converter to battery) are sufficient gauge to run the rig's 12v from the battery when not on shore power/converter, so they stay as is.
The new converter can run the rig's 12v by being on the battery which is connected to the fuse panel, so all is good.
Use #4 short wire (under three feet each wire) from the 60 amp converter to the battery to be sure of getting your 60 amps. (if that is the size converter you get)
Thanks!
If I try the 100 amp first in that configuration will it mess anything up?
Reviews are saying it only puts out 80 amps tested and works fine on 15 amp circuits
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
