Steve92004
May 12, 2017Explorer
It has the two holes but only two fuses
The instructions are a little confusing about adjusting it
Also I was checking my RV wiring and the existing converter has two 8 gauge wires coming from each of the positive and negative terminals, one from each runs to the fuse panel and the other runs to the battery
If I relocate the converter to the front near the batteries what do I do about the wires that run from the converter directly to the fuse panel?
Thanks!
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
