Steve92004
May 13, 2017Explorer
beemerphile1 wrote:Steve92004 wrote:beemerphile1 wrote:
Again I ask, what size cables are in it now?
How far is it from converter to battery now?
I just got home and measured it
It's 15' of 8 gauge cable from the converter to the battery terminals
Output of of the converter is 13.7 volts at the terminals and 12.8 volts at the battery terminals
Eight gauge is too small. You will benefit from larger cable or moving it closer. If the location is 15' it actually translates to a 30' path for the electricity.
Dropping from 13.7 to 12.8 would indicate you have one or more corroded/loose/bad connections currently. That is a problem.
Thanks, the wires aren't looking great where they terminate at the battery
I'll be redoing those today when I yank that 12v battery and box and put in the 6's
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
