BFL13
May 13, 2017Explorer II
"here's a question, can I makeup for voltage drop just by adjusting the voltage so it's 14.6 at the battery end of the cables? "
Yes except you want 14.8 on your 6s. However once amps taper, the voltage drop isn't so bad, so now the battery post voltage will go up a bit. No big deal in the cold when you want higher voltages.
14.8 is for 77F/25C so if it is hotter out than that, you want to use slightly lower voltages anyway as "temperature compensation."
BTW please edit out-delete my quoted stuff from your 7:23 post so we don't confuse folks reading all this later with that wrong info. Thanks.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
