Steve92004
May 13, 2017Explorer
BFL13 wrote:
"here's a question, can I makeup for voltage drop just by adjusting the voltage so it's 14.6 at the battery end of the cables? "
Yes except you want 14.8 on your 6s. However once amps taper, the voltage drop isn't so bad, so now the battery post voltage will go up a bit. No big deal in the cold when you want higher voltages.
14.8 is for 77F/25C so if it is hotter out than that, you want to use slightly lower voltages anyway as "temperature compensation."
BTW please edit out-delete my quoted stuff from your 7:23 post so we don't confuse folks reading all this later with that wrong info. Thanks.
This is fascinating stuff
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
