was_butnotnow
Nov 19, 2017Explorer
westend wrote:
If the inverter didn't work on the 300W draw of the absorption fridge, it's doubtful that it will meet the start up draw of a residential compressor fridge. You may have been referencing the way things are wired and not the "didn't work" aspect of power demand.
Yes, you could use the circuit for the microwave. You would have to change the circuit wiring in the load center to operate off the microwave circuit.
An alternative is to add a second transfer switch into the load center, this additional transfer switch would power up the refrigerator receptacle's circuit.
Finally, using an extension cord to power the fridge may be the easiest solution.
It was designed not to have ac power at the fridge when in inverter mode since no one would want to run a 2-way gas/elc fridge on electric.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
