mtnbbud's avatar
mtnbbud
Explorer II
Oct 11, 2015
replacing nuts with chrome closed lug nuts?
I was thinking my trailer wheels would look a little nicer if I replaced them with chrome closed acorn wheel nuts. I found a set of 20 on Amazon for $20. Is there any reasons why I shouldn't do this? Could I switch the nuts straight across and be done? I don't have a torque wrench. My trailer is an 18ft Terry, dual axle, dry weight 3000lbs.
Thanks.
  • Your link shows 12mm Metric lugnuts. When I replaced the lugnuts on our previous trailer they were 1/2"X 20.
    Thanks.
    Here's the link to the nuts: I don't see much info to know if they are low quality or not. You may be right that buying direct might be a better idea. I was figuring I'd have a shop repack my trailer bearings rather than trying to do it myself. That'd be a good time to look into replacing the lug nuts.
  • How in Hades did an air wrench enter this discussion ? Insinuating that the **** studs on our trailer were ruined with an air wrench ? If so, this would be the first time I ever saw a Craftsman breaker bar and 1/2 " ratchet with an air fitting.
    The OEM wheel studs were roll threaded instead of cut. You can tell a roll thread -vs- a cut thread, at least I can, I spent the first 7 yrs of my working life as a tool and die maker before I started writing commercial software for a living. The first four or five threads are simply lifting off the stud.
    If fact, one of the ones that went bad froze the nut and I was able to break it with the Craftsman 1/2" standard sized breaker bar. That is junk steel if I can break it without having to put a pipe on the bar for leverage.
    The first couple threads are where a bolt has its most holding power, they actually are holding on all the threads.
    Think of how many times you get the tires on your car/truck rotated and balanced. I would surmise that there are a very small percentage that have the threads strip off the first time the lug nuts are removed.
    Cheap bolts/nuts on a working component are a hazard to your safety and are no place to cut corners. They have their place, I use them, just not on something that can kill me or someone else.
    The cheap lug nuts/studs go hand in hand with the rest of the fasteners on our unit. They rusted out in 2 years, had the heads popping of the screws, all systems of fasteners bought from the lowest bidder.
    I have replaced the rest of the screws/bolts in the unit with stainless.
    Find a small mom and pop shop that sells trailer parts, you might be surprised at the price that you will get the lug nuts for and you can be a bit less concerned about what you are buying as they have a vested interest in keeping you coming back.
  • Sometimes air impact tools do bad things and they have ruined many lug bolts. Well actually the guy with the trigger did it.
  • Are the threads per inch (TPI) the same ? How about the internal threading depth
    -vs- the amount of threads sticking through the wheel. Those are 2 major considerations.
    Also you need to consider where they are coming from. Our Crossroads Cruiser has junk wheel studs. The threads have simply pulled off on a lot of them. I have been slowly replacing them as they fail. (I put my good tires in the barn in the winter).
    There are lots of inferior quality fasteners that come from overseas. In my opinion, lug nuts are not one place where going cheaper is better.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 21, 2026
