BigWapiti
Jul 23, 2020Explorer
Replacing PD 9145A
I need to replace my power converter (PD 9145A). Since I'm needing to replace it - should I replace it with the same make/model unit or are there better options that I should go with instead?
BigWapiti wrote:
Turns out my 9145 didn't go bad as I thought - but I was reading about the charge wizard. I don't think mine has one assuming it would be wired or plugged in somewhere? If so, I see nothing external to the device itself.
Is this something worth buying separate if I do end up keeping the 9145 converter? Seems it was an option with this device, yes?
