westend
Feb 18, 2015Explorer
I would flash the edge of the OSB, scrape the loose stuff off the face and spray the exposed OSB with undercoating spray in a can. I'm guessing time of process to be around an hour.
If you need to dry out the slide, how about tenting it with plastic and putting a heater under there. If the heater doesn't have enough airflow, add a fan.
