TenOC's avatar
TenOC
Nomad
Oct 26, 2015
Replacing TT radio with used car radio ???
The 2002 radio in my TT died. Since new RV radios cost $$$, I looked on eBay without much luck. I am thinking about replacing the radio with a used car radio from a junk yard. That is a better radio for less money. I can rework the cut-out in the TT to fit the radio.
A friend said that:
(1) Many (most ?) car radios need am amplifier and will not power RV speakers directly. Is this true?
(2) Many new car radios have a locking code that is key to the car's VIN number that only the car dealership can change. This is to stop the steeling of radios.
How do I select a car radio that will work in my TT. . . .:h . . . Or is this a bad idea?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Many places including crutchfield (add www and com) sell the proper plug with pigtail or even adapt-a-plugs.
  • When it comes to an RV there usually are only two speakers possibly 4 so really all there is are the power, ground and speaker wires. The problem I have with mine is modern stereos have a second power wire that shuts the stereo off when you open the car door so if not hooked up to a switch of some sort the stereo stays powered up at all times until you kill the battery power in some way.
  • MEXICOWANDERER wrote:
    Mis-matched components will make your setup sound like a Mexican Hi-Fi
    Hijole !!
  • Thanks all . . . :B
    My TT has 2 front and 2 rear speakers and I have the wire color code from the old radio. Now I need to find a good deal on the radio I want or I need Santa to bring me one.
  • TenOC wrote:
    Thanks all . . . :B
    I pulled a Panasonic stereo out of my 2003 TT that I have absolutely zero use for. PM me your mailing address and I will mail it to you. Its a typical car stereo from the era, nothing fancy.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
