RJsfishin
Feb 06, 2015Explorer
If you get the universal pump designed to replace any shure-flo pump, you won't need anything else, except a blue butt connector for the cut black wire. Just unplug the red wire, and cut the black wire.
If there is no valve on the tank side of the pump. the tank will drain when you remove the intake side.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
