Old-Biscuit
May 31, 2016Explorer III
With only 15 gallon I would go with the 1 gpm/30 psi pump
And YES water coming out of the city water connection with pump running is a bad/jammed check valve (internal part of city water assembly)
You can change out the assembly or just get a garden hose shutoff or a PVC plug and screw it into the 3/4" hose connection
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
